C9200L enter mode 'switch:'
WanisaCh
c9200L ever factory reset all and boot image again.
Yesterday power cut. I reboot switch but switch enter mode 'switch:' again.
how to solve problem ?
24 Replies 24
conf t
 boot system bootflash:cat9k_lite_iosxe.17.09.02.SPA.bin
end
wr
i encounter same issue with owner,  my device is C9200L-48T-4G,
executed command boot system bootflash:cat9k_lite_iosxe.17.03.06.SPA.bin, it can come to <switch>.
but after execute follow:
conf t
end
wr
when restarted it show can not find the cat9k... file.
if not execute this command after restarted it will come switch: again.
WanisaCh
switch: boot system bootflash:cat9k_lite_iosxe.17.09.02.SPA.bin
boot: attempting to boot from [system]
switch: boot system usbflash0:cat9k_lite_iosxe.17.09.02.SPA.bin
switch:
Why are you trying to enter that command in ROMMON when the switch already booted into IOS?
I try follow you but i not see
SW_cisco2(config)#boot system bootflash:?
bootflash:.dbpersist bootflash:.installer
bootflash:.prst_sync bootflash:.rollback_timer
bootflash:.rommon_sync bootflash:Baltimore.ca
bootflash:DigiCertGlobalRootCA.ca bootflash:EDScisco
bootflash:ISRGRootX1CrossSignDST.ca bootflash:SHARED-IOX
bootflash:StarfieldServicesRootCA.ca bootflash:Tbot
bootflash:boothelper.log bootflash:boothelper.log.old
bootflash:bootloader_evt_handle.log bootflash:core
bootflash:dc_profile_dir bootflash:dope_hist
bootflash:fp_cc_crash bootflash:lateshutdown.log
bootflash:license_evlog bootflash:memleak.tcl
bootflash:mode_event_log bootflash:nvram_config
bootflash:nvram_config_bkup bootflash:onep
bootflash:pnp-info bootflash:rdope.log
bootflash:rdope_out.txt bootflash:sys_report
bootflash:tech_support bootflash:vlan.dat
i enter command in rommon.
Boot the switch into IOS and copy the firmware file from the USB into the flash of the switch.
how to copy the firmware file from USB to flash of the switch?
In enable mode, the command is "copy usbflash0:filename.bin flash:".
Thank you Leo Laohoo for support.
it made me solve problem.
Happy to be of assistance.
