C9200L enter mode 'switch:'
WanisaCh
c9200L ever factory reset all and boot image again.
Yesterday power cut. I reboot switch but switch enter mode 'switch:' again.
how to solve problem ?
3 Accepted Solutions
conf t
 boot system bootflash:cat9k_lite_iosxe.17.09.02.SPA.bin
end
wr
Boot the switch into IOS and copy the firmware file from the USB into the flash of the switch.
In enable mode, the command is "copy usbflash0:filename.bin flash:".
24 Replies 24
Leo Laohoo
Put the firmware into a USB flash drive and use "emergency-install" (go straight to Step 5).
"emergency-install tftp://192.0.2.1/cat3k_caa-universalk9.
 SPA.03.03.00.SE.150-1.EZ.bin"
what is ip address "192.0.2.1" ? i can asign?
If the firmware is in a USB flash drive, then the correct syntax is:  emergency-install usbflash0:filename.bin
I can not use command "emergency-install"
In ROMMON, enter "?" and see what options appear.
WanisaCh
Interesting options available.
Try this:  "boot usbflash0:filename.bin".
I boot usbflash0:filename.bin can be used normally. But after reboot switch enter mode 'switch:' again.
Ok, now show me the complete output to the command "set".
I also need the first seven characters of the serial number.
Console into the switch and reboot.
Post the entire bootup process.
NOTE:  DO not post screenshots.
Ok, so the switch boots up successfully.
Now post the complete output to the command "sh boot".
hi Leo Laohoo
SW_cisco1#show boot
Switch 1
Current Boot Variables:
BOOT variable does not exist
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
