C9200L  PACL Question
el.wang
Does  , Anyone  can   make   sure   c9200L  network  essential  support   IPV4  PACL  or  not . All Document  I can  find    only
mention    support   IPV6 PACL only.
Scott Hodgdon
el.wang,
Yes, IPv4 Port ACLs are supported with 9200/9200L. Please reference the IPv4 ACLs chapter of the 9200 Configuration Guide at https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-3/configuration_guide/sec/b_173_sec_9200_cg/configuring_ipv4_acls.html . That one is for IOS XE 17.3.
If you require the configuration guide for a different release, please see https://www.cisco.com/c/en/us/support/switches/catalyst-9200-r-series-switches/products-installation-and-configuration-guides-list.html .
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
just out of curiosity, as I was looking at the same guide you have linked, does that mean that port ACLs are by default supported in Essentials ? I could not find any reference to whether you needs Essentials or Advantage...
Georg,
Yes, they are. Go to https://cfnng.cisco.com/ . Click the "Browse" box and then search by Switching product 9200L. Choose any release (I choose 16.12.1 for the oldest one in the tool) and Universal Network Essentials license. Click the Browse button and then filter with "port-based". You should see "Port-Based ACLs (PACLs)".
Cheers,
Scott Hodgdon
GL WANG
