C9200L-STACK-KIT
knaik99
Level 5
Level 5
Hi all,
if we want to order this stack kit then do we have to order stack cable separately or it is inbuilt with this kit?
Giuseppe Larosa
Hello Knaik99,
the 0,5 meters cable should be provided with the stack kit.
for longer cables you need to order them separately.
You can put in stack only C9200L devices a mix of C9200L and C9200 with modular uplinks is not supported ( the stack cables have different speed).
C9200L-STACK-KIT
Stack kit for C9200L SKUs only: Two data stack adapters and one data stack cable
see
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html#Featuresandbenefits
Hope to help
Giuseppe
