C9300 17.03.03 - cisco smart licensing validation
ziqex
Level 4
Level 4
I've moved C9300-24P to use cisco transport gateway for smart licensing.
Switch running version 17.03.03
Transport gateway is operational for other devices and is registered with smart licensing.
How can I renew authorization to verify if this is functional properly for this switch?
On Smart Software Licensing I can see last contact being 2021-Apr-22 16:18:58
destination address http http://10.22.50.10:8080/Transportgateway/services/DeviceRequestHandler
sh license all
Smart Licensing Status
Smart Licensing is ENABLED
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
Thank you.
Daniel
6 Replies 6
As a workaround I've manually imported the IdenTrust Commercial Root CA 1 but still don't see it communicating or even trying to communicate.
Daniel
 First, check the status:
show license summary
Here you can follow a guide to troubleshoting:
https://blog.octanetworks.com/cisco-smart-licensing-troubleshooting-steps-and-considerations-on-catalyst-platforms/
sh license summary
License Usage:
License Entitlement Tag Count Status
network-advantage (C9300-24 Network Advan...) 2 IN USE
dna-advantage (C9300-24 DNA Advantage) 2 IN USE
Daniel
Looks good, right?
Product instances in smart software licensing are showing last contact as 2021-Nov-11 19:05:38 for this device SN.
