C9300 thousandeyes enterprise agent using SVI
djhurley
Does anyone know it you can use the thousandeyes EA on a C9300 where the VLAN connecting the agent is mapped directly to an SVI on the switch rather than via a L2 front panel port? version 17.3.4 is running on the switch.
It's a branch switch, with only a L3 routed interface on the WAN side.
balaji.bandi
its app hosting as long it has communication to external that should i guess (technically)
below document may help you :
https://docs.thousandeyes.com/product-documentation/global-vantage-points/enterprise-agents/installing/cisco-devices/installing-enterprise-agents-on-cisco-catalyst-9000-series-switches
BB
I found the problem, as the switch is part of a stack and in this case the stack master is switch 2, i needed to configure app port 2/0/1 and not 1/0/1.
Dave
correct, but to make consistence, always 1/0/1 should be master.
BB
