C9300L-24T-E machine version 17.3 default padding settings
pignus93
I am using the C9300L-24T-E machine version 17.3 and was wondering what the padding default settings are?
Mark Elsen
              - Which padding settings are you referring to ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I didn't ask the right question.
What I was trying to ask is, do I need to use the "no service pad" command to block the pad service on those devices as well, or does the device have the ability to block the pad service by default?
balaji.bandi
Sure as asked before - what are you looking,
show run all  (give you all the default configuration if you are not configured any config)
BB
Sorry, I didn't ask the right question.
