C9400 SUP slot to be use for line card slots
CHNC
Is it possible to use C9400 one supervisor slot for linecards to connect endpoints..?
C9400 have 2 SUP slots, one among is using as SUP and other one is empty as of now. So we thought to use it for Linecards. Is it possible..?
Please post your comments with any documented links.
Thanks in Advance..!
Mark Malone
No they should have a different physical pin out on the sup card if you try a line card you may break the chassis back plane
Catalyst 9404R Switch—Slots 2 and 3 only (redundant supervisor modules supported). The primary supervisor module can be installed in either slot.
Catalyst 9407R Switch—Slots 3 and 4 only (redundant supervisor modules supported). The primary supervisor module can be installed in either slot.
Catalyst 9410R Switch—Slots 5 and 6 only (redundant supervisor modules supported). The primary supervisor module can be installed in either slot
