C9407R OS UPgrade
seyuncho15677
Hello.
I have C9407R ( sup-1XL ).
And configured Stackwise-virtual.
What I'm curious about is how to change from existing bundle mode to install mode during OS upgrade.
Do I have to connect to each terminal through the console and type the install command?
If I need to keep the bundle mode, do I copy the os file to each equipment and reload only the active equipment?
** Equipment Information **
- Chassis : C9407R
- SUP : C9400-SUP-1XL
- Version : 16.12.2r
- Upgrade Version : 17.6.5
- OS mode : bundle mode
thank you.
Leo Laohoo
1.  Change the boot variable string to point to "packages.conf":
conf t
 no boot system flash bootflash:OLD_IOS.bin
 boot system flash bootflash:packages.conf
end
wr
2.  Use the following command to convert from Install Mode to Bundle Mode:
install add file bootflash:IOS_FILENAME.bin activate commit
NOTE:  Step 2 will extract the package files from all Supervisor Cards.
WARNING:  At the end of Step 2, both chassis will reboot.
5 Replies 5
Leo Laohoo
conf t
end
wr
Hi, Thank you for your reply.
Will the standby hot equipment in Stackwise-virtual also be upgraded if I run step 2?
No need.
Step 2 will unpack the packages from the Primary and the Secondary Supervisor cards.
Thank you very much.
Um...Can I ask you one more question?
Do I have to have an os file in the active and hot standby equipment 'bootflash:' before work?
Yes, if using Bundle Mode.
No, if using Install Mode.
