C9500-40X dual active problem
ortelacl
Scenario#1
The dual-active does not work as indicated. When we remove the dual-active link both switches shutdown there access interfaces. Only 1 switch should shutdonw its access interfaces.
The dual-active is directly configured over the two switches (direct link). [hardware = C9500-40X, image =
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.8.1a, RELEASE SOFTWARE (fc1)].
Scenario#2
When we configured the dual-active over de access layer. The stand-by switch disable all its access interfaces when we turn of the active switch. Fail-over does not work.
Does anyone have experience this problem? Please help.
andresfr
Hello ortelacl,
According to documentation:
DUAL ACTIVE DETECTION
If a StackWise Virtual link fails
, the Cisco StackWise Virtual standby switch
cannot determine the state of the Cisco StackWise Virtual active switch. To
ensure that switchover occurs without delay, the Cisco StackWise Virtual
standby switch assumes that the Cisco StackWise Virtual active switch has
failed and initiates switchover to take over the Cisco StackWise Virtual
active role. The original Cisco StackWise Virtual active switch enters
recovery mode and brings down all the interfaces except the StackWise
Virtual link and the management interfaces.
So, the dual-active detection triggers when there's StackWise Virtual link failure, and not when there's a failure of the Dual-Active-Detection link. Only the original Cisco StackWise Virtual active switch should be the one entering in recovery mode and bringing down all the interfaces except the StackWise Virtual link and management interfaces. The original standby switch will now become the new active switch with all its interfaces enabled and working.
Recovery Actions
A Cisco StackWise Virtual active switch that detects a dual-active condition shuts
down all of its non-SVL interfaces to remove itself from the network. The switch
then waits in recovery mode until the SVLs have been recovered. You should
physically repair the SVL failure and the recovery switch should be manually
reloaded for it to be the standby switch.
Reference link:
Dual-Active Detection
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-8/configuration_guide/ha/b_168_ha_9500_cg/b_168_ha_9500_cg_chapter_011.html#concept_sjb_byx_31b
Can you please share your current configuration for this StackWise Virtual setup?
Also, provide the output of the following commands
show stackwise-virtual
show stackwise-virtual switch 1
show stackwise-virtual switch 2
show stackwise-virtual link
show stackwise-virtual neighbors
show stackwise-virtual dual-active-detection
redundancy
mode sso
main-cpu
standby console enable
stackwise-virtual
domain 1
dual-active detection pagp trust channel-group 1
dual-active detection pagp trust channel-group 2
dual-active detection pagp trust channel-group 3
dual-active detection pagp trust channel-group 4
dual-active detection pagp trust channel-group 5
dual-active detection pagp trust channel-group 6
dual-active detection pagp trust channel-group 8
dual-active detection pagp trust channel-group 10
dual-active detection pagp trust channel-group 11
dual-active detection pagp trust channel-group 12
dual-active detection pagp trust channel-group 13
dual-active detection pagp trust channel-group 14
dual-active detection pagp trust channel-group 15
dual-active detection pagp trust channel-group 16
dual-active detection pagp trust channel-group 17
Stackwise Virtual Configuration:
Stackwise Virtual : Enabled
Domain Number : 1
Switch Stackwise Virtual Link Ports
1 1 TenGigabitEthernet1/0/37
TenGigabitEthernet1/0/38
TenGigabitEthernet1/0/39
2 1 TenGigabitEthernet2/0/37
TenGigabitEthernet2/0/38
TenGigabitEthernet2/0/39
Domain Number : 1
Domain Number : 1
Stackwise Virtual Link(SVL) Information:
Flags:
Link Status
U-Up D-Down
Protocol Status
S-Suspended P-Pending E-Error T-Timeout R-Ready
Switch SVL Ports Link-Status Protocol-Status
1 1 TenGigabitEthernet1/0/37 U R
TenGigabitEthernet1/0/38 U R
TenGigabitEthernet1/0/39 U R
2 1 TenGigabitEthernet2/0/37 U R
TenGigabitEthernet2/0/38 U R
TenGigabitEthernet2/0/39 U R
Stackwise Virtual Link(SVL) Neighbors Information:
Switch SVL Local Port Remote Port
1 1 TenGigabitEthernet1/0/37 TenGigabitEthernet2/0/39
TenGigabitEthernet1/0/38 TenGigabitEthernet2/0/38
TenGigabitEthernet1/0/39 TenGigabitEthernet2/0/37
2 1 TenGigabitEthernet2/0/37 TenGigabitEthernet1/0/39
TenGigabitEthernet2/0/38 TenGigabitEthernet1/0/38
TenGigabitEthernet2/0/39 TenGigabitEthernet1/0/37
Dual-Active-Detection Configuration:
Switch Dad port Status
#show stackwise-virtual dual-active-detection pagp
Pagp dual-active detection enabled: Yes
In dual-active recovery mode: No
Channel group 1
Dual-Active Partner Partner Partner
Port Detect Capable Name Port Version
Te1/0/1 Yes .d Te8/1/1 1.1
Te2/0/1 Yes Te1/1/1 1.1
Channel group 2
Te1/0/2 Yes  Te6/1/1 1.1
Te2/0/2 Yes Te1/1/1 1.1
Channel group 3
Te1/0/3 Yes Te6/1/1 1.1
Te2/0/3 Yes Te1/1/1 1.1
Channel group 4
Te1/0/4 Yes .d Te2/1/1 1.1
Te2/0/4 Yes  Te1/1/1 1.1
Channel group 5
Te1/0/5 Yes  Te1/1/2 1.1
Te2/0/5 Yes  Te1/1/1 1.1
Channel group 6
Te1/0/6 Yes  Te1/1/2 1.1
Te2/0/6 Yes  Te1/1/1 1.1
Channel group 7
Te1/0/7 No  Te2/1/1 N/A
Te2/0/7 No  Te1/1/1 N/A
Channel group 8
Te1/0/8 Yes  Te2/1/1 1.1
Te2/0/8 Yes  Te1/1/1 1.1
Channel group 9
Te1/0/9 No  N/A
Te2/0/9 No  N/A
Channel group 11
Te1/0/11 Yes  Te1/1/2 1.1
Te2/0/11 Yes  Te1/1/1 1.1
Channel group 12
Te1/0/12 Yes . Te2/1/1 1.1
Te2/0/12 Yes . Te1/1/1 1.1
Channel group 13
Te1/0/13 Yes . Te2/1/1 1.1
Te2/0/13 Yes . Te1/1/1 1.1
Channel group 14
Te1/0/14 Yes . Te1/1/1 1.1
Te2/0/14 Yes . Te2/1/1 1.1
Channel group 15
Te1/0/15 Yes . Te2/1/1 1.1
Te2/0/15 Yes . Te1/1/1 1.1
Channel group 16
Te1/0/16 Yes n. Te2/1/1 1.1
Te2/0/16 Yes n. Te1/1/1 1.1
Channel group 17
Te1/0/17 Yes n. Te1/1/2 1.1
Te2/0/17 Yes n. Te1/1/1 1.1
Channel group 18
Te1/0/18 No n. Te1/1/2 N/A
Te2/0/18 No n. Te1/1/1 N/A
Channel group 22
Te1/0/22 No n. Te1/1/2 N/A
Te2/0/22 No n. Te1/1/1 N/A
ortelacl
Scenario#1
n#show stackwise-virtual
Domain Number : 1
Domain Number : 1
nl-bxt1-mer1-cs01n#
Domain Number : 1
#show stackwise-virtual link
Flags:
Link Status
U-Up D-Down
Protocol Status
nl-bxt1-mer1-cs01n#
#sh stackwise-virtual ba
sh stackwise-virtual bandwidth
Switch Bandwidth
1 30
2 30
sh stackwise-virtual dual-active-detection p
#sh stackwise-virtual dual-active-detection pagp
Channel group 1
Te1/0/1 Yes  Te8/1/1 1.1
Channel group 2
Te1/0/2 YesTe6/1/1 1.1
Channel group 3
Channel group 4
Te1/0/4 Yes Te2/1/1 1.1
Te2/0/4 Yes n Te1/1/1 1.1
Channel group 5
Channel group 6
Channel group 7
Channel group 8
Channel group 9
Te1/0/9 No  Te2/1/1 N/A
Te2/0/9 No  Te1/1/1 N/A
Channel group 10
Te1/0/10 Yes  Te2/1/1 1.1
Te2/0/10 Yes  Te1/1/1 1.1
Channel group 11
Channel group 12
Te1/0/12 Yes nl. Te2/1/1 1.1
Channel group 13
Te1/0/13 Yes. Te2/1/1 1.1
Te2/0/13 Yes Te1/1/1 1.1
Channel group 14
Te1/0/14 Yes Te1/1/1 1.1
Te2/0/14 Yes nTe2/1/1 1.1
Channel group 15
Te1/0/15 Yes  Te2/1/1 1.1
Te2/0/15 Yes Te1/1/1 1.1
Channel group 16
Te1/0/16 Yes  Te2/1/1 1.1
Te2/0/16 Yes  Te1/1/1 1.1
Channel group 17
Te1/0/17 Yes  Te1/1/2 1.1
Te2/0/17 Yes  Te1/1/1 1.1
Channel group 18
Te1/0/18 No  Te1/1/2 N/A
Te2/0/18 No . Te1/1/1 N/A
Channel group 22
Te1/0/22 No . Te1/1/2 N/A
Te2/0/22 No . Te1/1/1 N/A
