C9500-48Y4C IOS-XE Upgrade in SVL mode
rashad_cisco
Hi Guys
we have faced the upgrade process of Catalyst C9500-48Y4C in SVL stack.
Is there any method to perform upgrade without reboot of both switch or reload them in turn ?
Br
Rashad
Leo Laohoo
Yes, there is.  Refer to the attachment and go straight to Chapter 2.
Hope this helps.
Hi Leo Laahoo
thanks for your reply and information.
But I am wondering about such methods as ISSU and use some redundancy features of SVL technics.
Because here 24/7 business and reload of switches is not so acceptable during non-business our even.
Make sure raise a pro-active Cisco TAC when performing an ISSU upgrade.  TAC must be on a WebEx session and watching because if the ISSU fails, it fails spectacularly.
rashad_cisco
Hi Guys
may be for someone will be useful following links regarding C9500-48YC SVL stack switches soft upgrade:
 https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/17-9/configuration_guide/ha/b_179_ha_9500_cg/configuring_issu_on_stackwise_virtual.html
they say that you can upgrade SVL cluster soft version via ISSU.
Br
Rashad
