Port in suspended mode between cisco 9300 and avaya
arouna.kikone1
Hi ALL
I have two Cisco 9300X-24Y-E stacked switches. I want to implement etherchannel between my cisco switches with an avaya switch.
After the configurations and the interconnection of the switches, the port-channel goes into "suspended" mode.
Note that the cisco 9300 switch does not allow me to type the command "Switchport trunk encapsulation dot1q".
Need your help to solve this problem which prevents me from evolving in my project.
below is the ports config in etherchannel:
CONFIGURE ETHERCHANNEL LACP
SW_SI_DC_NTX(config)# interface range twentyfiveGigE1/0/23-24,twentyfiveGigE2/0/23-2/0/24
SW_SI_DC_NTX(config-if-range)#channel-protocol lacp
SW_SI_DC_NTX(config-if-range)#channel-group 40 mode active
SW_SI_DC_NTX(config-if-range)# exit
SW_SI_DC_NTX(config)#interface port-channel 40
SW_SI_DC_NTX(config-if)#switchport mode trunk
interface Port-channel 40
interface TwentyFiveGigE1/0/23
interface TwentyFiveGigE1/0/24
interface TwentyFiveGigE2/0/23
interface TwentyFiveGigE2/0/24
SW_SI_DC_NTX#sh running-config interface port-channel 40
Building configuration...
Current configuration : 68 bytes
duplex full
end
SW_SI_DC_NTX#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SD) -
40 Po40(SD) LACP Twe1/0/23(D) Twe1/0/24(s)
Twe2/0/23(D) Twe2/0/24(D)
SW_SI_DC_NTX#show interfaces twentyFiveGigE 1/0/24
TwentyFiveGigE1/0/24 is up, line protocol is down (suspended)
Hardware is Twenty Five Gigabit Ethernet, address is c02c.17fd.7e98 (bia c02c.17fd.7e98)
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
input flow-control is on, output flow-control is unsupported
Last input 00:00:00, output 00:00:19, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 31000 bits/sec, 49 packets/sec
3603671 packets input, 382205571 bytes, 0 no buffer
Received 3455251 broadcasts (449542 multicasts)
6 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 449542 multicast, 0 pause input
12949 packets output, 1488007 bytes, 0 under runs
Output 0 broadcasts (12949 multicasts)
0 output errors, 0 collisions, 3 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW_SI_DC_NTX#
Sorry, what I meant is that the Avaya seems not to be understanding the LACP from cisco side.
I would try mode "on" just to make sure
72 Replies 72
The port channel is SD' meaning it down?
In SW you need to do these step in these seq
1- make port member of PO
2- config PO
3- no shut PO
Please @MHM Cisco World  what does PO stand for?
PO Port channel
Hi @arouna.kikone1
  If you connect both switches only with one interface the interfaces come up correctly?
If yes, configure the port-channel with the "on" and "passive" mode.  Just to make sure the mode is not wrong considering the Avaya side.
channel-group number mode {active | on | passive}
@Flavio Miranda I connected the two switches with only one port but the port-channel always remains in "suspended" mode
 But without port-channel the interface stay UP ?  Just trying to make sure you dont have a problem on the basic which is interface.
yes without the PO port 24 is UP when we connect the cable as you can see on the outputs of the command "show interfaces twentyFiveGigE 1/0/24" that I shared above
@Flavio Miranda @MHM Cisco World
you can see the lacp config on the avaya switch in the attached file
LACP and TRUNK on avaya switch
@arouna.kikone1  the configuration seems to be ok but I would like to confirm with you are able to get the interface up without the port channel config.
@Flavio Miranda yes without the PO port 24 is UP when we connect the cable as you can see on the outputs of the command "show interfaces twentyFiveGigE 1/0/24" that I shared above
One port the PO is up add other one the PO is down'
Try
PO shut
connect cable to both port
PO no shut
The PO is down because of stp issue
@MHM Cisco World we are at the weekend of here work resumes on Monday.
I'll check the track you put me on and get back to you.
Yes' also share show lacp internal when you back to site.
