C9500-48Y4C switch uplink down detection
Charlie Grey
i am using the C9500-48Y4C as an aggregate switch.
its uplinks are EC to another C9500 switch and the down links connect to Access switches.
is there a method to monitor the uplink status so that the down links will all be disabled in event when the uplinks are lost?
Mark Elsen
 - In a generalized manner  you could monitor the up link with snmp and or snmp manager software coupled with an attached event-handler which can do anything you want when the up link goes down.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
barweiss45
Yes, this could be easily achieved with EEM Scripting. See the documentation in the link below. Depending on how you want to monitor the uplink (either by state for physical or by an IP SLA for layer3) you can have the EEM script to react to the event of either an IP becoming unreachable or the interface going in the down state. When the event occurs it will trigger the EEM script.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/configuration/xe-16-10/eem-xe-16-10-book/eem-policy-cli.html
HTH,
Barry
