C9500 stackwise and hsrp
nikcasiraghi
i got 2 brand new Cisco C9500-48Y4C, sw level 17.3.4 with essential license.
Question 1 : is it true that I need advantage license to use them in stackwise ?
Question 2 : I tried to set them as separate devices but I cannot define HSRP or VRRP to overcome the problem in question 1
Is it true that this model / sw is not supporting layer3 redundancy protocols like HSRP or VRRP ?
Thanks for your support.
Nicola.
2 Accepted Solutions
Reza Sharifi
See table-16 in this link.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9500-series-switches/nb-06-cat9500-ser-data-sheet-cte-en.html
You need "Network Advantage" license for both "StackWise Virtual and HSRP".
Hello
@nikcasiraghi wrote:
Question 1 : is it true that I need advantage license to use them in stackwise ?  Correct
Is it true that this model / sw is not supporting layer3 redundancy protocols like HSRP or VRRP ? - HSRP is supported an  advantage license is required
Features
Network Essentials
Network Advantage
Advanced switch capabilities and scale
BGP, EIGRP, HSRP, IS-IS, BSR, MSDP, PIM SM, PIM SSM, PIM-BIDIR, IP SLA, OSPF
High availability and resiliency
NSF, ISSU, StackWise Virtual
Kind Regards
Paul
Reza Sharifi
Thank you both Reza and Paul,
very helpful information.
I've found out that VRRPv3 is supported so i set the 2 C9500 in standalone (no stackwise) with VRRP redundancy.
VRRP setup is described in the documentation at this link (for Ios 16.6 but valid also for the 17.3.4 I have)  :
VRRPv3
Hello
Features
Network Essentials
Network Advantage
Kind Regards
Paul
