c9500 stackwise virtual DAD problem
Keith Lawrence
I have been scratching my head trying to get out new pair of c9500s configured.
I have set up stackwise virtual and have successfully connected both switches. Everything looks fine and config is correct.
I then connected a port on each switch with a direct fibre to use for Dual Active Detection and applied the "stackwise-virtual dual-active-detection" command on each port and rebooted the pair of switches.
When the switches came back up, the DaD ports were no longer lit up and the show stackwise-virtual dual-active-detection command showed both ports as down. I can confirm the SFP modules and the fibre are fine - it seems to to be the action of adding the DaD commands that causes them to shut down.
Any ideas what I am doing wrong??
9 Replies 9
Leo Laohoo
My suspicion is it's a bug with the software.
I think you may be right. Ive erased and rebuilt the config from scratch about 6 times with no change.
Ive logged a TAC call so will wait and see what happens.
Georg Pauwen
on a side note, which IOS version are you running ? I checked the bug tool but couldn't really find one relating to your specific issue.
I suppose you have already made sure that both switches are running the same license level.
Can you post the configurations of both ports ?
Hi Georg,
Its a new model of switch so there is only one IOS-xe available for it - cat9k_iosxe.16.06.01
The config is also very simple. te1/0/39-40 and te2/0/39-40 are stackwise virtual links and connected directly with fibre. te1/0/1 and te2/0/1 are DaD links and also connected directly with fibre.
SFPs work fine and fibre polarity is correct. Stackwise-virtual is much more basic than VSS but the principles are still the same.
stackwise-virtual
domain 1
te1/0/1
te1/0/39
stackwise-virtual link 1
te1/0/40
te2/0/1
te2/0/39
te2/0/40
Have same problem. Opening TAC
Forgot to update my original post - tac confirmed it is not supported yet for that model of 9500. Roadmap shows support around march next year.
Keith, thanks for the information.
Cheers
Carmelo Jimenez
Orange County Sheriff – Information Systems
Thanks for the update.
