C9504 ssh port change issue
dudgkr
Hi.
Model Name: N9K-C9504
nx-os: 7.0.3
I want to change to a port other ssh port
config t
ssh port command not working
1. Is it not supported in version 7.0.3?
2.Do I need to upgrade the version?
help me
according to the security configuration guide, you need version 9.2(1) or higher:
--> Changing the Default SSH Server Port
Beginning with Cisco NX-OS Cisco Release 9.2(1), you can change the SSHv2 port number from the default port number 22
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/92x/security/configuration/guide/b-cisco-nexus-9000-nx-os-security-configuration-guide-92x/b-cisco-nexus-9000-nx-os-security-configuration-guide-92x_chapter_0111.html
balaji.bandi
Your version not support, you need to uplift to 9.2 or higher code of NXOS with below syntax can be configfured.
ssh port local-port
Example:
switch(config)# ssh port 58003
BB
