12-28-2018 07:57 AM - edited 03-08-2019 04:54 PM
Hello peers!
I THINK i have a simple question, but it's just an odd quirky one. I have a couple standalone, un-stacked 2960Xs out there with a stacking module in the back. Proactive monitoring software is picking those up as critical, down stacking ports because they're not hooked up to another stacking module (bc it's a standalone switch).
When I remove the cards, the proactive monitoring software is still showing the system as having them - is there something i can do to remove them from a hardware database (like deleting a vlan.dat to clean out vlans would do)?
I don't see anything in CLI for provisioning the module
I dont see any stacking modules in show-inventory
Next thoughts?
Thx!
12-28-2018 09:37 AM
What is your monitoring software (I hope it's not called Proactive)? I would look at getting the software to ignore the stack module state.
12-28-2018 09:50 AM
i think i figured it out. The tool is solarwinds - but i wanted to point to the cisco device and how to straighten myself out with it. :)
I have told the monitoring software to ignore those interfaces, but there is automation built into that software, it may re-discover it.
I looked back through the config, and i THINK what it's doing is... I entered a "switch 1 priority 15" command, even though there isn't a stack - and the switch somehow assumes it's god a module - somewhere only Solarwinds would be smart enough to pick up from!
12-28-2018 10:06 AM
Nice. Yeah, we run SW too. We just click list resources when on the node page and select or un-select interfaces and save. No auto re-discovering in ours although that seems more useful than not.
