Cabling
junshah22
Hi All,
please tell me what type of cable is exactly required for connecting a Router's Ethernet port to a Switch's Ethernet port.....
I found on some discussions and forums on other sites that Cross Over cable is required....BUT
I am using a 2621 Router with a D-Link switch and I am connecting it with a Straight-through cable and it is working fine....
this straight cable can also connect a PC to Switch...
please guide.
Thanks in advance
Junaid
Jon Marshall
Hi Junaid
Router to switch - straight-thru
PC to switch - straight-thru
Router to Router - crossover
switch to switch - crossover
PC to router - crossover
Jon
mahmoodmkl
Level 7
Level 7
As jon said u need to use a straight cable to connect switch and router,and same for switch to PC.
Mahmood
