Calculating Delay for changing routing path
saravanababu22
I have configured an multilink, problem is after configuration, end to end connectivity was fine, but the traffic which is being initiated from my end is via different path,
found that the FD is lesser in the different path, i need to use delay value so that the traffic is via multilink.
router1#sh ip eigrp topology 10.158.128.144/28
IP-EIGRP (AS 100): Topology entry for 10.158.128.144/28
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 1814016
pls suggest
router2#sh ip eigrp topology 10.158.128.144/28
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 1813760
Giuseppe Larosa
Hello Saravan,
to understand how to change delay the best starting point is show interface
show interface type x/y
compare the output of the multilink with that of the current exit interface to the current best path to the destinations
be aware that changes done in this way have global impacts.
To make changes only for selected destinations you should use the offset-list command inbound to the current outgoing interface.
example:
router eigrp 100
offset-list 11 in 50 typex/y
see
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_eig2.html#wp1012264
Hope to help
Giuseppe
