Calculation CPU utilization in 6509-E
Nikolay Savin
Community Member
I service 6509-E
when i issue command show proc cpu sorted 5min I watch next a picture
CPU utilization 5 min is 70%
And summ of all process is 23.37% only
please explain which value is correct?
and how I can see who consume remain percent of CPU?
Best Regards, Nikolay
CPU utilization for five seconds: 63%/42%; one minute: 71%; five minutes: 70%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
 296  3153677696 242468641      13006  5.67%  6.07%  6.26%   0 Earl NDE Task
 317  2844460780 158231874      17976  4.23%  4.88%  4.73%   0 IP Input
 540  2254748736 574308272       3926  3.75%  3.07%  3.01%   0 Port manager per
  11  11736604441637676955        716  2.47%  2.63%  2.63%   0 ARP Input
  23   860412388 954003205        901  0.00%  0.93%  0.93%   0 IPC Seat Manager
   8   710168988  35011308      20284  0.00%  1.02%  0.89%   0 Check heaps
 612   4608868161018570877        452  0.47%  0.42%  0.64%   0 SNMP ENGINE
 311   315823056 412270495        766  0.39%  0.37%  0.37%   0 CDP Protocol
 406   106981588 132498833        807  0.31%  0.34%  0.32%   0 CEF: IPv4 proces
  65    779048844190505306          0  0.39%  0.33%  0.32%   0 IP SLAs Event Pr
  50    58358328  89044108        655  0.39%  0.32%  0.32%   0 Per-Second Jobs
 360   189545140  21576987       8784  0.07%  0.25%  0.26%   0 QOS Stats Gather
 344     59705561697818939          3  0.23%  0.25%  0.24%   0 Ethernet Msec Ti
  59   170533676 363032750        469  0.31%  0.24%  0.24%   0 VSIBC process
 602    133519202517354999          0  0.23%  0.19%  0.22%   0 IP RACL Ager
 610   1633247921328627206        122  0.07%  0.14%  0.22%   0 IP SNMP
  85    93616192 173952151        538  0.23%  0.20%  0.18%   0 ARP HA
 319   126166220 908586954        138  0.15%  0.18%  0.17%   0 ADJ resolve proc
 261    20380252 228824679         89  0.15%  0.14%  0.15%   0 cpf_process_tpQ
 603   149469036 255715724        584  0.07%  0.13%  0.11%   0 DHCPD Receive
 120    65741720  31282448       2101  0.07%  0.10%  0.09%   0 IPC LC Message H
 419     5872504 224549711         26  0.00%  0.13%  0.08%   0 FM core
 507    39473272 388536414        101  0.07%  0.07%  0.07%   0 RPC online_diag_
 595    11387112  83028518        137  0.07%  0.08%  0.07%   0 Net Serv Timer
 539     45759001948397675          2  0.07%  0.07%  0.07%   0 PM Callback
 448     43614482517182523          0  0.07%  0.05%  0.07%   0 RADIUS
  20    12153168  81383134        149  0.00%  0.05%  0.07%   0 IPC Periodic Tim
 285     49441442551510651          0  0.00%  0.06%  0.07%   0 ACE Tunnel Task
 621    20284512 854469486         23  0.00%  0.06%  0.07%   0 EIGRP-IPv4 Hello
 611    58230348 657402881         88  0.00%  0.04%  0.07%   0 PDU DISPATCHER
 583    13314848   1242906      10712  0.00%  0.00%  0.06%   0 crypto sw pk pro
 607     5859036 173163513         33  0.07%  0.04%  0.05%   0 MLSM Process
  51    70874564   2485622      28514  0.00%  0.07%  0.05%   0 Per-minute Jobs
 427    30477752  40737753        748  0.07%  0.04%  0.05%   0 HIDDEN VLAN Proc
 134     8673860  14199767        610  0.07%  0.04%  0.05%   0 Compute load avg
 605    16284920 872736878         18  0.00%  0.05%  0.05%   0 IGMP Input
 176         492       168       2928  0.07%  0.19%  0.05%   3 Virtual Exec
  63    24755752 813667581         30  0.07%  0.04%  0.04%   0 Net Input
 606     7839408  88273250         88  0.00%  0.03%  0.01%   0 PIM Process
 597      836864 880913273          0  0.00%  0.02%  0.01%   0 fastblk backgrou
 130     1887072 677441476          2  0.00%  0.01%  0.01%   0 Mwheel Process
  32    13271864  45669814        290  0.23%  0.02%  0.00%   0 EnvMon
InayathUlla Sharieff
Nikolay,
answer:- This is average amount of high cpu seen by the device.
2-
Current cpu CPU utilization for five seconds: 63%/42%;
First 63% means process traffic and 42% is interupt traffic.
23 % is your process traffic which means that the packets is hitting the sotware cpu.
Troubleshooting the high cpu on 6500:
https://supportforums.cisco.com/document/59926/troubleshooting-high-cpu-6500-sup720
Inayath
**Please dont forget to rate the post if helpfull**
Nikolay,
2-
Inayath
