Calhoun LED Proc
aquiros099
We have four identically configured Cisco Switches (2950 running 12.1(22)EA2)
One of them has a high CPU (20%) while the rest are 1%. None of them are really doing much, no traffic currently going through them. The one with a high CPU has this process to blame...
20 400615112 49492703 8094 16.95% 16.97% 16.01% 0 Calhoun LED Proc
While the others are much lower...
20 569772 59394695 9 0.00% 0.00% 0.03% 0 Calhoun LED Proc
spremkumar
Level 9
Level 9
CPU process in switches normally represents STP processing/port processing and LED indicators..
And as per the supporting doc its a normal behavior to have highest percentage of cpu utilisation by these processes..
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094e78.shtml
regds
Amit Singh
The CPU on the 2950 switch normally runs around 20-40% with no load. The LED processors are usually between 8 and 20% even in a no load situation.
Calhoun LED Process: decoded means that this switch has the Calhoun board, (this is a nick name that the programmers gave it) and that the processor is running at x%. LED is referring to the actual LED's on and in the switch.It has been seen that this does not affect the switch performance.
The Calhoun does a lot of things:
- Updates statistics and error counters in port LED config, to update the blink profile.
- For each port, calculates the next color to be displayed based on the blink profile and the mode.
As I mentioned, this value is seen very often and if the switch is not having any latency issues, it should not cause a problem.
HTH,Please rate if it does.
-amit singh
