CamMiss exception in port-asic on Catalyst 3020
kiyoteru.tanaka
I have catalyst blade switch 3020. It displays the following message a lot. I would like to know what this message means and what I should do against this. Could you give me any advice?
* CamMiss exception in port-asic 1
The port-asic 1 is used for port 5, 6, 13 and 14.
Switch 1, PortASIC 1 Registers
GlobalPortNumber                   : 00000005 00000006 0000000D 0000000E
There is "camMiss" in ExceptionIndexTable of port-asic.
switch1#show platform port-asic exception asic 1
NoDestIndex: 00000153
DropDestIndex: 00000154
ExceptionIndexTable
    aclDeny                 0154
    mtuTooLarge             0154
    camMiss                 0154     < ---
    icmpRedirect            0034
Kiyoteru
Viral Bhutta
The error message is printed when the TCAM lookup fails because of a
fault with TCAM programming or hardware error with  TCAM itself.
Can you please send me show version?
Also, have you tried to reload the device? How often are you getting these error messages? Do you have any connectivity issues?
I'm sorry my reply is late. And I appreciate your answer for my question.
I've already replaced the device, then this message seems to have disappeared. ( The message appeared every 1 minutes. ) So there might have been something wrong with TCAM as you mentioned.
Let me confirm one more my understanding. "camMiss" in  ExceptionIndexTable of port-asic indicates just destination was dropped from the index (0154:DropDestIndex), right? (so TCAM lookup fails)
Kiyoteru
mukdahan#sho ver
Cisco IOS Software, ME340x Software (ME340x-METROIPACCESSK9-M), Version 12.2(53)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 13-Dec-09 17:46 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is ME340x boot loader
BOOTLDR: ME340x Boot Loader (ME340x-HBOOT-M) Version 12.2(44r)EY, RELEASE SOFTWARE (fc1)
mukdahan uptime is 27 weeks, 4 days, 7 hours, 18 minutes
System restarted at 02:01:26 bkk Fri Feb 14 2014
System image file is "flash:/me340x-metroipaccessk9-mz.122-53.SE/me340x-metroipaccessk9-mz.122-53.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ME-3400EG-12CS-M (PowerPC405) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1439X4F2
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
16 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : B4:A4:E3:A9:FF:00
Motherboard assembly number     : 73-11447-09
Motherboard serial number       : FOC14395SUQ
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : ME-3400EG-12CS-M
System serial number            : FOC1439X4F2
Top Assembly Part Number        : 800-29835-03
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : COMBU00BRA
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 16    ME-3400EG-12CS-M   12.2(53)SE            ME340x-METROIPACCESSK9-M
Configuration register is 0xF
I will try.
Every 3 seconds.
Thank you very much.
