Campus QoS: WTD-Thresholds on Egress Queue
rolf.fischer_2
Hi all,
I've been trying to analyze the Auto-QoS-Config of a Catalyst 2960 and there is one command I don't understand:
mls qos queue-set output qset-id threshold queue-id drop-threshold1 drop-threshold2 reserved-threshold maximum-threshold
What I don't understand particularly are the values for drop-threshold 1 and 2.
Example:
mls qos queue-set output 1 threshold 1 138 138 92 138
Possible values are between 1-3200 and now I'm asking myself what is the purpose of WTD-Thresholds of more than 100% (138% in this case)?
Guess I misunderstand the command...
Rolf
Giuseppe Larosa
Hello Rolf,
command reference says
>>The drop-threshold percentages can exceed 100 percent and can be up to the maximum (if the maximum threshold exceeds 100 percent).
so the sample config statement is correct.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/command/reference/cli1.html#wp2144505
the command is strictly related to this
mls qos queue-set output buffers
that is the one that provides the buffers absolute size for the queue-set.
I agree that is not clear and not expected to see a percentage going above 100%.
Hope to help
Giuseppe
