Can a port configure both trunk and access mode?
getaway51
Level 2
Level 2
1)May I know the port config below is a trunk port or access port?
2)If it is an access port vlan 3, does voice using vlan 2 still works ? because i rmbr an access port cannot be vlan member of more than one vlan. Only trunk port can.
interface GigabitEthernet1/0/1
switchport access vlan 3
switchport trunk allowed vlan 1,2
switchport mode access
switchport nonegotiate
switchport voice vlan 2
Thanks a lot guys!!
luis_cordova
Hi @getaway51
R: The port is an access port:
Trunk related commands will only take effect when the port is in trunk mode.
R:The switch ports are enabled to allow data and voice traffic at the same time.
I attach this link about the voice vlan:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swvoip.html#wp1034062
Does this means tht data and voice vlan can both works even when the port is access mode provided voice vlan command is present? Is this something called HYBRID port in other switch? Not all switch support this kind of mode right?
Also does it means tht "switchport trunk allowed vlan 1-2" only active when the port is configured trunk mode and currently it doesnt means anything when the port is access mode?
Cisco calls it Multi-vlan access port which really means trunk port.
All Cisco POE switches support this kind of mode as long as the ports are connected to Cisco phones.
That is correct. As long as the mode is "access" any trunk related command under that interface is useless. The same way the other way around, when the mode is "trunk" any access related command under that interface is useless.
Also, have a look at this link and look for
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4500-series-switches/69632-configuring-cat-ip-phone.html
Configure the Switch Port to Carry Both Voice and Data Traffic
section
