Can ACL block source and dest IP on layer 2 interface?
after1111
I want to allow only a few subnets across the trunk link switch.
Can ACL block source and dest IP on a layer 2 interface?  e.g
int Gi0/1
switchport mode trunk
switchport trunk allowed vlan 3, 4
ip acces-group ACL-LIST in
OR
ACL can only block traffic on layer 3 interface? e.g
interface vlan 100
ip add 10.10.10.10 255.0.0.0.0
cheers
after1111 wrote:
Hi Jon,
3750.
I was told you cant apply ACL on a layer 2 interface because its only read frame, not IP, is this true?
No it's not true. The 3750 supports normal IP access-lists on L2 ports and L2 trunk ports, the main restriction being it can only be applied in the inbound direction -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/configuration/guide/swacl.html#wp1667255
Jon
Jon Marshall
which switch ?
Jon
Hi Jon,
3750.
after1111 wrote:
Hi Jon,
3750.
Jon
