04-18-2017 07:23 AM - edited 03-08-2019 10:14 AM
04-18-2017 07:34 AM
Yes of course , though access or trunk , but they work fine together either way
04-18-2017 07:37 AM
For 2960, the ports are 10/100 and for 3850 the ports are 10/100/1000. So, it should work fine assuming you are using copper ports. If it is 2960-S, than they support 10/100/1000 as well.
04-18-2017 10:36 AM
