Can Cisco device work with other vender device for MACSEC function in switch-to-switch mode?
LunY
We want to implement a feature like this: transfer data encrypted by MACSEC between the uplink ports on our device with Cisco's device in switch-to-switch mode. (The CAK is manually configured. SAK is generated and updated following MKA protocol. Calling MACSEC API to configure PHY chip.)
Is it possible to create a MACSEC link between a Cisco device and another vendor device in switch-to-switch mode? (I saw that "Cisco TrustSec device" is required for MACSEC feature) If it can, what's the configure on the Cisco device side?
Hello
I would have thought it would be however It seems non cisco isn’t supported, unless that is ive misinterpreted the MACsec documentation.
MACSEC:
Two keying mechanisms are available: Security Associati
on Protocol (SAP) and MAC Security Key Agreement (MKA).
SAP is a proprietary Cisco
®keying protocol used between Cisco switches
Kind Regards
Paul
Hello
MACSEC:
Kind Regards
Paul
Hi Paul,
Thanks for your reply. By searching your comments as the keyword, I got the guide
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/design-zone-security/how_to_intro_macsec_ndac_guide.pdf
Inside the guide, it describes "the switch-to-switch encryption uses Cisco’s proprietary SAP instead of MKA", be consistant with your reply.
Lun
