can i change Mgmt-vrf for switch 9400
mhbirri
Hi All,
I'm using Cisco 9407 switches as switch core and i want to activate smart account licences in switch, so how can i change Mgmt-vrf to another vrf MGMT is ready created, because i can't reach the internet from default vrf Mgmt-vrf
SW-CORE-RMTB#show vrf brief
Name Default RD Protocols Interfaces
Admin <not set> ipv4 Vl310
Vl311
Vl312
Vl313
Vl314
Vl315
Vl316
Vl319
Client <not set> ipv4 Vl332
Vl348
Vl349
Vl396
Vl412
Vl428
Vl460
Kelio <not set> ipv4 Vl390
Vl391
Vl392
MGMT <not set> ipv4 Vl352
Vl356
Vl357
Vl359
Mgmt-vrf <not set> ipv4,ipv6 Gi0/0
Micros <not set> ipv4 Vl320
Vl321
Vl322
Others <not set> ipv4 Vl360
Vl364
Vl368
Vl369
Vl370
Vl372
Vl376
Vl381
Vl382
Vl383
Vl384
Vl385
Vl389
Vl484
SW-CORE-RMTB#
marce1000
                         >... because i can't reach the internet from default vrf Mgmt-vrf
  The    vrf Mgmt-vrf is fixed attached to the management interface gi0/0 (e.g.) ; it can not be changed , perhaps the licensing servers can be reached through other network-paths and or vlans (?)
 M.
the licensing servers can be reached through other network-paths and or vlans ?
Yes this is my question, could i activate smart account licences through other network VRF ?
No need to worry about any VRFs. Just create an SVI with an IP for one of the vlans you have already created and make that vlan/IP routable to the Internet.
example for vl311
Interface vlan 311
ip address: xx.x.x.x mask y.y.y.y
no shut
ip route 0.0.0.0 0.0.0.0 (next-hop IP)
Make sure the IP you assign is reachable to and from the Internet. Once that is done, you can now work on activiting the license.
