Can I connecting two ports from router to stacking switches.
Mahmoud Marie
We have two Cisco CBS 350 "Stacked" connecting the ISPs routers with the SDWAN.
My question is can I connecting two ports from one ISP router to these switches, as I need to connect one port to CBS-1 and second port to CBS-2. as the below diagram
Appreciate your help
If the SW is stack you can config PO between ISP and two SW.
But CBS have many bug so it can PO not work properly.
MHM
balaji.bandi
what ISP router ? does the ISP router supports that ?
what is the use case to connect both the switch  - failure scenario ?
BB
jpelletier01
There are a lot of "ifs" to this question and I think we need more information.
