10-23-2019 02:27 PM
Below is what i got in the terminal. i have a catalyst 3560 24-POE connected to a Modem-Router. It is posible to get communication between the gig port and the Modem-router port?
GigabitEthernet0/2 is down, line protocol is down (err-disabled)
Hardware is Gigabit Ethernet, address is 001d.707c.c782 (bia 001d.707c.c782)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
--More--
10-23-2019 02:38 PM - edited 10-23-2019 02:39 PM
GigabitEthernet0/2 is down, line protocol is down (err-disabled) - what modem router other side ?
its in error disabled mode,
do the below steps :
config t
interface gi 0/2
shutdown
no shutdown
end
connect the interface to modem and test, if this is still now working
change the speed to 100 and with no negotiation command.
10-23-2019 03:41 PM
10-23-2019 05:13 PM
As others have mentioned it's down because of err-disabled. error-disabled can happen because of belwo reasons:
Duplex Mismatch
Loopback Error
Link Flapping (up/down)
Port Security Violation
Unicast Flodding
UDLD Failure
Broadcast Storms
BPDU Guard
Please run below command and see the reason of err-disabled:
show interfaces status err-disabled
Do you have port security or BPDU guard enabled on the port ?
if not , I suspect it's duplex mismatch , Is your other switch half duplex? Try changing the speed and duplex manually and see if the port comes up?
