Can I multiple connection between 2 swtiches?
Roy Lee
For some special arrangement, I would like to connect 2 access ports from a 3550 switch to 3560 switch.
1 port for vlan 200, another port for vlan 201.
Will this introduce bad thing to the switches?
Roy
4 Accepted Solutions
cadet alain
It won't cause any trouble.
Regards.
Alain.
BY default, cisco runs pvst and does the same as you discussed.
Parvesh
Ganesh Hariharan
Roy
Hello Roy,
As stated it wont cause any problem but best way you to configure the ports in tunk configuration with vlan allowed over the trunk.
Hope to Help !!
Ganesh
It would not as long as you care about the proper STP version to implement (PVSTP+) !!!
Alessio
cadet alain
Regards.
Alain.
Parvesh
Ganesh Hariharan
Roy
Hello Roy,
Hope to Help !!
Ganesh
Alessio
