Can i reduce the speed of 10G (SFP-10G-LR) module to 1G in Cisco WS-C2960X series Switch.
I am trying to connect 1G uplink from remote switch to 2960X 10G sfp port, but not able to change the port speed to 1G, as a result uplink is not coming up. Is it possible to reduce the 10G SFP module speed to 1G in 2960X switch
Reza Sharifi
No, that is not possible.  You would need to use the same type of SFPs and speed on both sides.
devils_advocate
Level 7
Level 7
You will need to replace the 10Gb SFP with a 1Gb one as it will not negotiate down.
The ports on the 2960x are SFP+ meaning they should support both 1Gb and 10Gb SFP's.
