can i run STP on STACKED switches?
vasanth77
how a spanning tree will run on stacked switches?
Aaron Harrison
Exactly the same way as you would run it on a chassis switch, or a single non-stacked switch.
The only conceptual difference is that the stack is a single entity, or single bridge from the STP point of view. Don't think of the switches as seperate (assuming a 'proper' stack like 3750s etc with specific 'backplane' connectors). They have a single 'brain' overseeing the whole stack, so you cannot and would not want to make them seperate STP entities.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
