Can I use Catalyst 6504E slot2 for ethernet module or service module?
iotoiotoioto
I am thinking composition of catalyst6504E.
can I use slot2 of catalyst6504E for ethernet module or service module?
cisco configuration tool answer OK.
But cisco power calclator point out me.
configuration tool
     WS-C6504-E
     Catalyst 6500 Enhanced 4-slot chassis,5RU,no PS,no Fan Tray
      S733AEK9-12233SXI
      Cisco CAT6000-SUP720 IOS ADVANCED ENTERPRISE SERVICES SSH
      WS-SUP720-3B
      Catalyst 6500/Cisco 7600 Supervisor 720 Fabric MSFC3 PFC3B
      CF-ADAPTER-SP
      SP adapter for SUP720 and SUP720-10G
      WS-SVC-FWM-1-K9
      Firewall blade for 6500 and 7600, VFW License Separate
      WS-X6748-GE-TX
      Cat6500 48-port 10/100/1000 GE Mod: fabric enabled, RJ-45
      WS-X6724-SFP
      Catalyst 6500 24-port GigE Mod: fabric-enabled (Req. SFPs)
      FAN-MOD-4HS
      High-Speed Fan Module for 7604/6504-E
      PWR-2700-AC/4
      2700W AC Power Supply for Cisco 7604/6504-E
      CAB-7513AC
      AC POWER CORD NORTH AMERICA (110V)
SlotLine CardOutput Current(@42V)
(A)
Output Power
(W)
Typical Power Used
(W)
Heat Dissipation
(BTU/Hr)
FAN2FAN-MOD-4HS1.4360.0648.05241.30
1WS-SUP720-3B6.72282.24225.791133.94
2WS-SVC-FWM-16.72282.24225.791133.94
3WS-X6724-SFP4.93207.06165.65831.89
4WS-X6148A-GE-TX2.50105.0084.00421.85
(A)
Output Power
(W)
Typical Power Used
(W)
Heat Dissipation
(BTU/Hr)
Total22.30936.60749.283762.93
Slot 2 is redundant supervisor-engine slot. It will allocate either the power of a supervisor engine or of the line card, whichever is greater. The Actual Output Current, Out Power and Heat Dissipation for your selected line card are 4.09A,171.78W,and 690.15 BTU/Hr
2 Accepted Solutions
According to the table above and as Jon stated yes you can.
Francisco
As pointed out by Francisco you can use redudant slot for any module you like.
Jon
6 Replies 6
Jon Marshall
Not sure what you are asking. Both your outputs show that you can indeed use slot 2 for any module you want.
Perhaps you could clarify.
Jon
thanks, Jon.
sorry, I just saw "Slot 2 is redundant supervisor-engine slot. "
and my colleague say it's impossible.
so I asked.
did anyone use that composition?
Chassis
Supervisor Engine 32/ Supervisor Engine 720 Slots
Classic Line-Card Slots
Single Fabric Connected Line Cards
Dual Fabric Connected Line Cards
Cisco Catalyst 6503
1 and 2
2 and 3
2 and 3
WS-X67XX line cards not supported
Cisco Catalyst 6503-E
1 and 2
2 and 3
2 and 3
2 and 3
Cisco Catalyst 6504-E
1 and 2
2 thru 4
2 thru 4
2 thru 4
Cisco Catalyst 6506
5 and 6
1 through 6
1 through 6
1 through 6
Cisco Catalyst 6506-E
5 and 6
1 through 6
1 through 6
1 through 6
Cisco Catalyst 6509
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6509-E
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6509-NEB
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6509-NEB-A
5 and 6
1 through 9
1 through 9
1 through 9
Cisco Catalyst 6513
7 and 8
1 through 13
1 through 13
9 through 13
Francisco
Jon
thank you all.
I agree with you.
