Can interface port-channel run concurrently both L2 & L3.
r.hew
MY team is doing migration at remote site. They have similar two C6509 connected back via fiber.
Before migration below is the command in Core 1;
interface GigabitEthernet8/1
description to-Core2-L3PortChannel1-link1
no ip address
mls qos trust dscp
carrier-delay msec 0
channel-group 1 mode active
interface GigabitEthernet8/2
description to-Core 2-L3PortChannel1-link2
no ip address
mls qos trust dscp
interface GigabitEthernet9/1
description to-Core2-L3PortChannel1-link3
no ip address
mls qos trust dscp
interface GigabitEthernet9/2
description to-Core2-L3PortChannel1-link4
no ip address
mls qos trust dscp
interface Port-channel1
mls qos trust dscp
dampening
interface Port-channel1.900
description to-ABF608.DC.GR.CR65.2-Area0
encapsulation dot1q 900
ip address 10.62.247.213 255.255.255.252
ip ospf network point-to-point
interface Port-channel1.901
description to-ABF608.DC.GR.CR65.2-Area332
encapsulation dot1q 901
ip address 10.41.125.249 255.255.255.252
When tried to configure a VLAN eg. 998 and configure int port-channel vlan 998 as below;
interface Port-channel1.998
description Migration VLAN
encapsulation dot1q 998
The question is we can't key in the encapsulation dot1q 998 and the switches comment that it's already existed.
Is there other command that might have left out or the int port-channel just support L3 subinterface only and not L2 subinteface.
steve.busby
Level 5
Level 5
Sounds like they already have Vlan 998 in use--perhaps an SVI? What is the output of "show ip int brief"?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/layer3.html#wp1040486
Steve
Thanks for your prompt reply.
I did tried it personally in the lab and I got the following message;
PTT351.T01.08.DC.ED6(config-subif)#enc dot1Q 998
Command rejected: VLAN 998 not available
Below cmd the complete "sh run" that I get my remote engineer to send to me;
vlan 998
name Migration-VLAN
dampening
mtu 9216
no ip address
mls qos trust dscp
encapsulation dot1Q 900
encapsulation dot1Q 901
ip pim sparse-mode
description to-ABF608.DC.GR.CR65.2-L3PortChannel1-link1
mtu 9216
no ip address
wrr-queue cos-map 1 1 1
wrr-queue cos-map 2 1 0
wrr-queue cos-map 3 1 4
wrr-queue cos-map 3 2 2
wrr-queue cos-map 3 3 3
wrr-queue cos-map 3 4 6
wrr-queue cos-map 3 5 7
mls qos trust dscp
description to-ABF608.DC.GR.CR65.2-L3PortChannel1-link2
mtu 9216
no ip address
mls qos trust dscp
description to-ABF608.DC.GR.CR65.2-L3PortChannel1-link3
mtu 9216
no ip address
mls qos trust dscp
description to-ABF608.DC.GR.CR65.2-L3PortChannel1-link4
mtu 9216
no ip address
mls qos trust dscp
For your information, there is no int vlan 998 created yet.
So I believed, the port channel can only have either L2 or L3 and can't support both together.
Thanks.
Raymond
