04-23-2013 02:57 AM - edited 03-07-2019 12:58 PM
This is my customer's N7K.
sw7010a2# sh module
Mod Ports Module-Type Model Status
1 32 1/10 Gbps Ethernet Module N7K-F132XP-15 ok
3 48 10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L ok
5 0 Supervisor module-1X N7K-SUP1 active *
6 0 Supervisor module-1X N7K-SUP1 ha-standby
9 8 10 Gbps Ethernet XL Module N7K-M108X2-12L ok
10 8 10 Gbps Ethernet XL Module N7K-M108X2-12L ok
The module 1 was no empty port.
Is anybody using LC-SC patch cord connect X2-10GB-SR (on N7K-M108X2-12L) between SFP-10G-SR (on N5K)?
Thanks.
04-23-2013 05:42 AM
If your fiber patch is LC to SC (Single Mode) it should work just fine. I have not used LC to SC between Nexus platforams but have used LC to SC to connect 5Ks and 7ks to 6500.
04-23-2013 04:03 PM
Yes, it'll work fine as long as your fibre patch cord is Multi-Mode.
05-01-2013 01:05 PM
Should work just fine as long as it's multi-mode, as stated above.
Also, if there are any jumpers in between, make sure you're not mixing 62.5/50 micron together.
05-20-2013 06:22 AM
I would like to know which patch cord should I be using between X2-10GB-SR and IBM 10GBase-SR 10GbE 850 nm Fiber SFP+ Transceiver.
05-20-2013 01:52 PM
You need LC to SC Multimode
