Can not format flash
Michael Ricci
I am trying to upload the faxmail application onto my 2801 ISR, but am getting the following error when I try to upgrade
DWR_Unity#copy ftp flash
Address or name of remote host []? x.x.x.x
Source filename []? app_faxmail_onramp.2.0.1.3.tcl
Destination filename [app_faxmail_onramp.2.0.1.3.tcl]?
Accessing ftp://x.x.x.x/app_faxmail_onramp.2.0.1.3.tcl...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
%Error erasing flash: (No device available)
%Error erasing flash (No device available)
I tried typing in "format flash:" but I get this error
DWR_Unity#format flash:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "flash:".  Continue? [confirm]
Enter volume ID (up to 64 chars)[default flash]:
%Error formatting flash (No device available)
Any ideas?
10 Replies 10
Peter Paluch
Michael,
Although I am not sure if that helps, try using colons when using the copy command, i.e.:
copy tftp: flash:
Also, what is the IOS version you are running currently? What does the show flash: filesys command say?
Best regards,
Peter
Reza Sharifi
As Peter noted, try it like this:
T-1#copy ftp: flash:?
flash:128MB.sdf                    flash:c2800nm-adventerprisek9_ivs-mz.124-3g.bin  flash:common.tar  flash:es.tar
flash:home.shtml                   flash:home.tar                                   flash:sdm.tar     flash:sdmconfig-28xx.cfg
flash:sslclient-win-1.1.0.154.pkg  flash:startup-config
This above is from a 2821 router
Also, is your ftp server reachable?
Reza
Reza Sharifi
You can also format the flash first and them load the image, but make sure not to reboot the router until you load the new image to the flash, if not the router will not boot
format flash:
DWR_Unity#show flash: filesys
%Error show flash: (No device available)
As Glen noted, can you issue "sh ver" and see if you even have  a flash card? if you do, the last line of the output should show some thing like below:
62720K bytes of ATA CompactFlash (Read/Write)
Results of show ver
DWR_Unity#sho ver
Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 30-Apr-07 18:24 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
DWR_Unity uptime is 1 week, 5 days, 9 hours, 34 minutes
System restarted at 11:23:30 UTC Tue Nov 2 2010
System image file is "flash:c2801-adventerprisek9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 7.0) with 238592K/23552K bytes of memory.
Processor board ID FTX1137W12N
2 FastEthernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
1 DSP, 16 Voice resources
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
I don't see a CF in sh ver.  If there is one you should see this line in sh ver:
If there is one then it is not inserted all the way or it is defective
glen.grant
I'll the ask question first , is there a compact flash installed or is it possible someone walked off with it ?  Did you try resetting the compact flash card?
Yes there's a compact flash card installed
How would I reset the compact flash card? I tried format flash: with no success
Leo Laohoo
1.  Are you sure the CF is properly seated?
2.  Can you try a different CF?
3.  Is this a Cisco proprietary CF or a 3rd party CF?
Eject the CF with the lever.  Be sure that the CF is properly inserted.  Inserted incorrectly and the pins will bend/break.
