can not ping some loopback interfaces
njconnect
Frequent Visitor
Frequent Visitor
I am using packet tracer to prepare for my CCNA exam
I created the following network environment
I have (2) 3560 multilayer switches.  I have created a port channel trunk interconnecting the 2 switches using ports Gi0/1 - Gi0/2.
I created 2 VLAN and assigned them ip address
VLAN 2: ip address 192.168.2.1/24
VLAN 3: ip address 192.168.3.1/24
On Switch 1 I've created interface Loopback 0 with ip address 10.0.0.1 255.255.255.255
On Switch 2 I've created interface Loopback 0 with ip address 10.0.0.2 255.255.255.255
I've enabled IP routing on both switches
i Have one server connected to port fa0/2 which is vlan 2.  I can ping both
VLAN and pcs in those vlan as well as the loopback interface of Switch1 from the switches and computers.  I can not ping the switch2 loopback interface from Switch one or any of the computers.
I don't understand why.  Essentially what i would like to be able to do is assign each switch a loopback interface that i can ping from the all the computers.
I've included the config for both switches below.  I've also included paketTracer file.  switch logon is username superman password krypton
Switch 1 config
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Switch1
ip routing
ip ssh version 2
ip domain-name nina.com
spanning-tree mode pvst
interface Loopback0
interface Port-channel1
switchport mode trunk
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
switchport nonegotiate
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 3
interface GigabitEthernet0/1
channel-group 1 mode active
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan2
mac-address 0001.97b3.ee01
ip address 192.168.2.1 255.255.255.0
interface Vlan3
mac-address 0001.97b3.ee02
ip address 192.168.3.1 255.255.255.0
ip helper-address 192.168.2.10
ip classless
ip flow-export version 9
end
Switch 2 config
version 12.2(37)SE1
hostname Switch2
ip routing
ip ssh version 2
interface Loopback0
interface Vlan1
no ip address
shutdown
ip classless
end
5 Replies 5
Georg Pauwen
the easiest way would probably be to run RIP on both switches:
router rip
version 2
network 0.0.0.0
Can you give that a try ? Otherwise, post the Packet Tracer project file (zip it first before uploading)...
I've gone ahead and added the packettracer file.  switch username superman password krypton
what are your requirements ? Since both 3560 switches are L3 switches, and you have IP Routing enabled, you need to configure the default gateway for each PC on the directly connected switch. I can completely rebuild your network to get it to work, but what requirements is this based on ?
I've disabled ip routing on Switch2 and set the default-gateway 192.168.2.1 as per your suggestion.
The basic requirements are
1. 2 switches interconnected with a trunk port
2. at least 2 vlans configured
3. vtp enabled
4. loopback interface on each switch should be reachable from computers or other devices.
5.  I should be able to ping all computers, vlans and loopback interfaces
The packet tracer file has already been uploaded in the original post
along with with the configuration of both switches
