Can not traceroute beyond NAT
henry
We are NATing the outside source address of the serverA.
Our configuration:
ServerA (172.23.1.5/24)
RouterA (Eth0- 172.23.1.1/24, S0- 172.16.3.2/30)
RouterB (S0- 172.16.3.1/30, Eth0- 192.168.27.2/29)
Firewall
ServerB (198.203.239.66)
We can ping and traceroute from ServerA to ServerB but not the way around. NAT is happening on RouterB.
I enabled debug on both routers. When pinging from ServerB to ServerA I can see the correct translation and forwarding of packets,but on RouterA nothing happens.
Part of running-config on RouterA:
ip route 192.168.27.0 255.255.255.248 172.16.3.1
ip route 198.203.239.66 255.255.255.255 172.16.3.1
Part of running-config on RouterB:
interface FastEthernet0
ip address 192.168.27.2 255.255.255.248
ip nat inside
speed auto
interface Serial0
ip address 172.16.3.1 255.255.255.252
ip nat outside
encapsulation ppp
ip nat outside source static 172.23.1.5 192.168.27.13
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.3.2
ip route 198.203.239.64 255.255.255.192 192.168.27.1
Am I missing anything ? Please help.
Henry
6 Replies 6
Hello Henry,
can you try and remove both static routes from Router A:
and instead add just a default:
ip route 0.0.0.0 0.0.0.0 172.16.3.1
GP
I've tried. The same result.
Actually what I need is to connect serverA and serverB through 'sqlnet'. When I run 'plsql' statement on ServerB trying to quiry ServerA I can see on the RouterB NATing and routing seem to be correct. RouterA - nothing happens ???
Henry
on your Router B, try to add a static route specifying the subnet where the translated address is belonging to:
ip route 192.168.27.8 255.255.255.248 172.16.3.2
or try and use a different address for the NAT, e.g.
ip nat outside source static 172.23.1.5 192.168.26.13
and then adjust the routing accordingly.
HTH,
GP
Hello Henry,
can you post the output of ´debug ip nat´ from router B ?
GP
I've tried all the possible configurations on the RouterB with the same result. BTW on RouterA I can see sometimes (randomly) the debugging output.
The following is the debugging output from running 'sqlplus' on the ServerB trying to connect to ServerA on port 1251:
Output on RouterA:
*Mar 3 01:26:00: IP: s=198.203.239.66 (Serial0), d=172.23.1.5 (FastEthernet0),
g=172.23.1.5, len 48, forward
*Mar 3 01:26:00: TCP src=60934, dst=1521, seq=762687828, ack=0, win=24820 S
YN
Output on RouterB is attached (because of file size).
When I run 'sqlplus' on routerB it just times out.
Any ideas?
Henry
Hello Henry,
can you see anything being blocked in your firewall ?
GP
