Can Ping From Outside Cisco 2821 Interface But Not Inside Interface
mebernstein
Problem:
I Can Ping the internet (yahoo.com) From Outside(WAN) Cisco 2821 Interface But Not Inside Interface(LAN).
Setup:
I currnetly have a linksys RV082(192.168.0.1) connected to two ISP's. Connected to one of the switch ports on the RV082 is a Cisco 2821(WAN ip: 192.168.0.4). The Cisco 2821 is then connected to a regular switch, and compters are connected to that. The LAN ip on the Cisco 2821 is "192.168.4.1".
Suspected Problem:
Some of the default routes are not correct. (There may be other problems however) Any help is appreciated.
Default routes:
Cisco...0.0.0.0 0.0.0.0 192.168.0.1
Cisco...0.0.0.0 0.0.0.0 GigabitEthernet0/1 (WAN)
Cisco...0.0.0.0 0.0.0.0 GigabitEthernet0/0 (LAN)
Linksys...192.168.4.0 255.255.255.0 192.168.0.102
_______________________________________
cisco configuration file:
Building configuration...
Current configuration : 1539 bytes
version 12.4
hostname CiscoRouter
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$QKvL$DNWm2th4qX.xx2vb1hmG1/
enable password August16
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.4.1 192.168.4.9
ip dhcp excluded-address 192.168.4.200 192.168.4.254
ip dhcp pool LAN_POOL
import all
network 192.168.4.0 255.255.255.0
lease infinite
voice-card 0
no dspfarm
archive
log config
hidekeys
interface GigabitEthernet0/0
description $ETH-LAN$
ip address 192.168.4.1 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ETH-WAN$
ip address dhcp client-id GigabitEthernet0/1
duplex auto
speed auto
router rip
network 192.168.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1 permanent
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip http server
no ip http secure-server
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.4.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password AUGUST16
login
scheduler allocate 20000 1000
end
mahmoodmkl
Level 7
Level 7
U need to use NAT for this.
try the below config.
under u r gig0/0
ip nat inside
under u r gig0/1
ip nat outside
exit
ip nat inside source list 1 interface gig0/1 overload
Mahmood
Thanks, but now I have another problem I have a 20%-40% ping sucess rate from my inside interface.
Remove the below line from u r config.
noip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
Mahmood
