Can't connect directly to switch enable mode with a scrypt password
kazue58
I have this weird problem.
I have done username *username* algorithm-type scrypt secret *password* on all my switches in an effort to heighten our security since on some of our switches it just makes a secret 7. But on some switches when i connect via SSH, i only get to User EXEC mode. If i then type enable i get "Error in authentication".
But, if i do username *username* privilege 15 secret *password* and try to connect with SSH, i go straight to enable mode.
I have seen this bug on both a 9300, 3850 and 2960S. I'm afraid if the switch reboots, i might not be able to connect to it again with having algorithm-type Scrypt enabled. Anyone have any idea to what is causing this?
balaji.bandi
what device model and IOS code running that having that issue ?
post sample show run config to look what your AAA config looks like ?  this looks like config typo issue i guess.
I have template it works as expected below :
username <username> privilege 15 password 7 <password>
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
BB
can I see the config of AAA for both case SW work and not work?
this can be if your config is mix of AAA and local username/password and with and without enable
thanks
MHM
