L3 Port-channel(LACP) over WAN -Catalyst Switch Chassis
Alan.A
We are planning to implement the below setup, we decided to use EtherChannels using LACP to equally load balance the traffic on both ISP circuits. When either of the circuit disconnect or have a problem, both switch will not received a LACPDUs and the physical link should be dropped from the bundle. The problem I can think with this setup is there will be a short period of blackhole of traffic because it will take 30 seconds for the LACP to remove a member from the bundle. That is why I added the command "udld port aggressive" on each physical member, this way the member will immediately unbundled itself once the member port change its state to err-disabled. Any thoughts?
MAIN office
**********6800x2 VSS switch************
interface GigabitEthernet1/X
no switchport
no ip address
speed 1000
duplex full
no negotiation auto
channel-group 100 mode active
interface GigabitEthernet2/X
no switchport
no ip address
speed 1000
duplex full
no negotiation auto
interface Port-channel100
bandwidth 200000
no switchport
ip address 10.10.10.1 255.255.255.252
Remote office
**********4500Ex2 VSS switch************
no switchport
no ip address
speed 1000
duplex full
no switchport
no ip address
speed 1000
duplex full
no switchport
bandwidth 200000
ip address 10.10.10.2 255.255.255.252
check LACP fast mode, it can reduce the timeout.
thanks
MHM
thanks
MHM
