Can't connect to web interface of 887VA Cisco Modem
Blake
I type in the gateway address of the modem in a web browser after connecting directly to it and nothing else. I get page cannot be displayed. This is after I was issued an address of 192.168.1.2 from the modem, which is 192.168.1.1
I don't got the IOS CLI Software because I don't have elevated privileges. Any suggestions? Thanks
not sure what you have configured so far, but make sure it looks like this (connect to the router console port with a console cable):
conf t
int vlan 1
ip address 192.168.1.2 255.255.255.0
exit
username "name" password 7 "password"
ip http server
ip http authentication local
After configuring the above, set the IP address of your computer to 192.168.1.1 255.255.255.0, and browse to 192.168.1.2, then use the username and password you have configured.
