unidirectional ping between vlans
marwa.jeljli1
Hi guys,
i have a problem with my vlans configuration. yesterday, i added a new subinterface in my server firewall in order to put there a new server. this new vlan has the same configuration as other ones associeted to old subinterfaces. But a strange behaviour was detected. from all others vlans i can ping the new server. But, the server is unable to communicate with others vlans.
To give you more details about the architecture:
-- I have two routing devices: the first one is the firewall witch permit the intervlan routing between the server's vlans.
-- A core switch (level 3) witch permit also the intervlan routing between all Vlan servers and other ones.
Thank you for help
Marwa
milan.kulik
Level 10
Level 10
if a Ping is working one direction (and no NAT involved), it should not be a routing issue.
FW rules missing/incorrect for the new VLAN, I guess?
BR,
Milan
