Can't get 'ip nat outside source static' working...Please Help.
d.serra
Hey Guys,
Having a problem with 'ip nat outside source static'.  When a client on the outside of the NAT router tries to ping the server on the inside, I can see that traffic to the destination is NATted but return traffic is not being unNATted which is causing pings to fail.
I have been pulling my hair out for hours on this.  I can make it work if I define inside and outside networks in the opposite direction and use 'ip nat inside static source' but having absolutley no luck with 'ip nat outside source static'
You help is immensley appreciated!!!
I have the following setup R1--(Inside)---R2---(outside)---R3.
R2 has fa0/1 configured as 'ip nat outside' and fa0/0 configured 'ip nat inside'
Router 1 - (Server receiving the PINGs)
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface FastEthernet0/0
ip address 10.1.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip http server
no ip http secure-server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.1.2.2
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
Router2 - (The NAT Router)
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip address 10.1.2.2 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
ip address 10.2.3.2 255.255.255.0
ip nat outside
duplex auto
speed auto
router eigrp 10
network 0.0.0.0
no auto-summary
no ip http server
ip nat outside source static 10.2.3.3 22.22.22.3
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
R2#
Router3 (Client router initiating the PINGs)
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback0
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
ip address 10.2.3.3 255.255.255.0
duplex auto
speed auto
no ip http server
ip route 0.0.0.0 0.0.0.0 10.2.3.2
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
end
phooghen
Could you try to add a static route on R3 for Network 22.22.22.0 and the next hop is 10.2.3.2
Have a look at:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f2f.shtml
