Can't get through 2960-s when using VPN
erick.hemmen
Hi all,
This problem has been breaking my brains for some tim enow. I'm having a strange problem where I'm not able to get through a Cisco 2960-S L2 switch when connected through vpn, while LAN-WAN traffic is working fine.
The situation on site is the following:
  • Cisco Asa 5512-X connected to Cisco 2960-S connected to Dell PowerConnect 6224
  • 172.16.0.228                            172.16.0.253                     172.16.0.99
When inside the network I'm able to get to the internet without a problem. The problem is within a vpn-session. When this session is succesfully started I can ping and manage the Cisco 2960-S switch, but I can't ping or manage the Dell switch from my laptop. I can however ping the Dell from the Cisco-switch.
Any help how to get the vpn-traffic up and running would be greatly appreciated.
Please see my configs for the Cisco's and the rebranded Cisco/Dell PowerConnect:
Asa 5512-X:
ASA Version 8.6(1)2
hostname 5512-X
domain-name exam.ple
names
interface GigabitEthernet0/0
speed 100
duplex full
nameif outside
security-level 0
pppoe client vpdn group WWW
ip address pppoe setroute
interface GigabitEthernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 172.16.0.228 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 0
management-only
regex blockex1 "/test/"
regex blockex2 "amazon\.com"
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Internal
subnet 172.16.0.0 255.255.255.0
object network 1
host 172.16.0.240
object service 1718T
service tcp source eq 1718
object service 1718U
service udp source eq 1718
object service 1719T
service tcp source eq 1719
object service 1719U
service udp source eq 1719
object service 1720T
service tcp source eq h323
object service 1720U
service udp source eq 1720
object service 5060T
service tcp source eq sip
object service 5060U
service udp source eq sip
object service 5061T
service tcp source eq 5061
object service 5061U
service udp source eq 5061
object service 60000T
service tcp destination range 60000 60020
object service 60000U
service udp destination range 60000 60020
object service VideorangeT
object service VideorangeU
object network remotevpn
subnet 192.168.199.0 255.255.255.0
object-group service Videorange udp
port-object eq 1718
port-object eq 1719
port-object eq 1720
port-object eq sip
port-object eq 5061
port-object range 60000 60020
object-group service Videor tcp
port-object eq 1718
port-object eq 1719
port-object eq h323
port-object eq sip
port-object eq 5061
access-list PermitOutsideIn extended permit icmp any any echo
access-list PermitOutsideIn extended permit icmp any any echo-reply
access-list PermitOutsideIn extended permit icmp any any source-quench
access-list PermitOutsideIn extended permit icmp any any time-exceeded
access-list PermitOutsideIn extended permit udp any object Video object-group Videorange
access-list PermitOutsideIn extended permit tcp any object Video object-group Videor
access-list nonat remark ACL for Nat bypass via VPN Client
access-list nonat extended permit ip 172.16.0.0 255.255.255.0 object remotevpn
access-list splitvpn remark ACL for VPN split tunnel
access-list splitvpn standard permit 172.16.0.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool remotevpn 192.168.199.10-192.168.199.15
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static Video interface service VideorangeU VideorangeU
nat (inside,outside) source static Video interface service VideorangeT VideorangeT
nat (inside,outside) source static Video interface service 1718U 1718U
nat (inside,outside) source static Video interface service 1718T 1718T
nat (inside,outside) source static Video interface service 1719U 1719U
nat (inside,outside) source static Video interface service 1719T 1719T
nat (inside,outside) source static Video interface service 1720U 1720U
nat (inside,outside) source static Video interface service 1720T 1720T
nat (inside,outside) source static Video interface service 5060U 5060U
nat (inside,outside) source static Video interface service 5060T 5060T
nat (inside,outside) source static Video interface service 5061U 5061U
nat (inside,outside) source static Video interface service 5061T 5061T
nat (inside,outside) source static Internal Internal destination static remotevpn remotevpn no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
access-group PermitOutsideIn in interface outside
route outside 0.0.0.0 0.0.0.0 37.0.81.170 1
route inside 172.16.1.0 255.255.255.0 172.16.0.99 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable 4433
http 172.16.0.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sysopt noproxyarp inside
crypto ipsec ikev1 transform-set remotevpn esp-3des esp-md5-hmac
crypto dynamic-map dyn1 1 set ikev1 transform-set remotevpn
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface outside
crypto isakmp nat-traversal 60
crypto ikev1 enable outside
crypto ikev1 policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
crypto ikev1 policy 10
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
encryption 3des
hash md5
group 2
lifetime 43200
crypto ikev1 policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh 172.16.0.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
vpdn group WWW request dialout pppoe
vpdn group WWW localname name
vpdn group WWW ppp authentication pap
vpdn username name password ***** store-local
dhcpd dns 8.8.8.8
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy remotevpn internal
group-policy remotevpn attributes
dns-server value 172.16.0.249 8.8.8.8
vpn-idle-timeout 120
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splitvpn
default-domain value exam.ple
username vpn password xxx encrypted
username adm password xxx encrypted privilege 15
tunnel-group remotevpn type remote-access
tunnel-group remotevpn general-attributes
address-pool remotevpn
default-group-policy remotevpn
tunnel-group remotevpn ipsec-attributes
ikev1 pre-shared-key *****
isakmp keepalive threshold 40 retry 5
class-map inspection_default
match default-inspection-traffic
class-map type inspect http match-any block-url-class
match request uri regex blockex1
match request header host regex blockex2
class-map bypass_traffic
match access-list PermitOutsideIn
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map type inspect http block-url-policy
parameters
class block-url-class
  drop-connection log
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
policy-map tcp_bypass_policy
class bypass_traffic
  set connection conn-max 256 random-sequence-number disable
policy-map custom-shaper-10000kbps
class class-default
service-policy global_policy global
service-policy custom-shaper-10000kbps interface outside
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 5
  subscribe-to-alert-group configuration periodic monthly 5
  subscribe-to-alert-group telemetry periodic daily
hpm topN enable
: end
Cisco 2960S:
version 12.2
no service pad
hostname C2960S
boot-start-marker
boot-end-marker
enable secret 5 xxx
enable password xxx
macro global description cisco-global | cisco-global
no aaa new-model
clock timezone UTC 1
clock summer-time UTC recurring last Sun Mar 2:00 last Sun Oct 3:00
udld aggressive
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos
spanning-tree mode rapid-pvst
spanning-tree loopguard default
errdisable recovery cause link-flap
errdisable recovery interval 60
vlan internal allocation policy ascending
interface FastEthernet0
ip address 192.168.0.254 255.255.255.0
interface GigabitEthernet0/22
switchport trunk native vlan 2
switchport mode trunk
mls qos trust cos
macro description cisco-router
spanning-tree portfast trunk
spanning-tree bpduguard enable
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
mls qos trust cos
macro description cisco-switch
spanning-tree link-type point-to-point
interface GigabitEthernet0/26
interface Vlan1
no ip address
interface Vlan2
ip address 172.16.0.253 255.255.255.0
interface Vlan3
ip address 172.16.1.253 255.255.255.0
interface Vlan8
ip address 192.168.199.254 255.255.255.0
ip default-gateway 172.16.0.228
ip http server
ip http secure-server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Rebranded Cisco/Dell PowerConnect:
!Current Configuration:
!System Description "PowerConnect 6224, 3.3.4.1, VxWorks 6.5"
!System Software Version 3.3.4.1
!Cut-through mode is configured as disabled
configure
vlan database
vlan 2-8,99,130
vlan routing 2 1
vlan routing 3 2
vlan routing 4 3
vlan routing 8 4
vlan association subnet 172.16.0.0 255.255.255.0 2
vlan association subnet 172.16.1.0 255.255.255.0 3
vlan association subnet 172.16.4.0 255.255.255.0 4
vlan association subnet 172.16.5.0 255.255.255.0 5
vlan association subnet 172.16.130.0 255.255.255.0 130
vlan association subnet 169.254.0.0 255.255.255.0 99
vlan association subnet 192.168.50.0 255.255.255.0 6
vlan association subnet 192.168.51.0 255.255.255.0 7
vlan association subnet 192.168.199.0 255.255.255.0 8
exit
snmp-server location "Server rack"
hostname "Core switches"
sntp unicast client enable
sntp server 172.16.0.249
clock timezone 1 minutes 0
stack
member 1 1
member 2 1
member 3 1
member 4 1
member 5 1
exit
ip address 172.16.151.99 255.255.255.0
lacp system-priority 120
ip routing
interface vlan 2
routing
ip address 172.16.0.99 255.255.255.0
exit
interface vlan 3
routing
ip address 172.16.1.99 255.255.255.0
exit
interface vlan 4
routing
ip address 172.16.4.99 255.255.255.0
exit
interface vlan 8
name "vpn"
routing
ip address 192.168.199.99 255.255.255.0
exit
username "adm" password xxx level 15 encrypted
line ssh
login authentication defaultList
exit
snmp-server enable traps captive-portal
snmp-server enable traps captive-portal client-connect
snmp-server enable traps captive-portal client-disconnect
interface ethernet 1/g1
switchport access vlan 2
exit
interface ethernet 1/g24
description 'Cisco2960'
switchport mode general
switchport general allowed vlan add 2,8
exit
enable password xxx
exit
mahmoodmkl
Level 7
Level 7
if the issue is then mark this thread as resolved which will benefit others
7 Replies 7
mahmoodmkl
Level 7
Level 7
U need to remove the ip default-gateway from 2960 and use ip route command and i dont see any default routes configured on ur dell switch.
Hi Mahmoodmkl,
Thanks for your answer. I got rid of the gateway on the 2960S and added this route on the Dell: ip route 192.168.199.0 255.255.255.0 10.0.0.228 20, but I still can't ping the Dell switch when connected through vpn. The 2960S is a Lan Lite switch, the ip route command unfortunatelty isn't working on this one.
Any help is greatly appreciated.
I think u need to have route on u r ASA as well for the subnet 172.16.0.0 255.255.255.0
Thanks again for your answer mahmoodmkl. The route to the 172.16.0.0/24 network is already on the ASA. It is added automatically in the config since the GE0/1 is in this network.
After removing the gateway on the 2960S-switch I couldn't ping this one anymore from the vpn-client so I added this one again onthe 2960S.
I believe the problem is somewhere between the 2960S and the Dell switches, but I can't really find out what it is.
mahmoodmkl
Level 7
Level 7
the royte is there for 172.16.1.0 not for 172.16.0.0
erick.hemmen
Got it working!
The problem was in the vlan 8 that was added to the Dell switch. After removing this vlan I was able to ping the entire network.
Thanks for your help and time mahmoodmkl.
mahmoodmkl
Level 7
Level 7
