Can't input ip secondary in switch [CLOSED]
after2nite
Hello everyone..
I want to add more 1 segment in 1 VLAN because it is to differentiate users on different floors.
For example :
for VLAN 100, there are 2 segments IP or 2 IP address for gateway , they are..
192.168.101.1
192.168.102.1 (as secondary IP or extend IP or multiply IP)
but when i type :
ip address 192.168.102.1 255.255.255.0 secondary
description appear : "Invalid input detected at '^' marker" (in switch layer 2 and MLS switch layer 3).
so.. how i make multiply or 2 segments in 1 VLAN ?
Please help me
Thank you very much..
7 Replies 7
It would help to know what switch and version you are using. And why do you try it on the Layer2 switch?
Anyhow, the better way is to use a new VLAN and assign the switchports for different floors to these different VLANs.
For switch layer 3 :
C3650-24PS ver 16.3.2
For switch layer 2 :
C2960-24TT-L ver 15.0(2)SE4
Ok thank you very much for your reply and suggestion
3650 should work as expected : (worth provide full show version - show ip route)
Usage Guidelines
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-2/command_reference/b_162_consolidated_3650_cr/b_162_consolidated_3650_cr_chapter_0101.html#wp1350715140
C2960-24TT-L ver 15.0(2)SE4  - if this is swich is layer2 ? what is the usecase here for secondary IP ?
BB
Dear,
Thank you very much for your reply & information.
i will try
I think you need to change SW to l3SW before add secondary IP to SVI.
Dear,
you welcome hope that help you to resolve the issue.
BB
