Can't ping 2950 switch from hosts
paquinjrm
Using a Win 7 laptop and a linux PC, I fail to connect to a 2950 switch.  Here is the Show Run:
Current configuration : 1324 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch_1
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
 ip address 192.168.10.1 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.10.1
ip http server
line con 0
 exec-timeout 30 0
 password cisco
 logging synchronous
line vty 0 4
 exec-timeout 30 0
 password cisco
 login
line vty 5 15
 exec-timeout 30 0
 password cisco
 login
end
Here is the Show Mac-Address table.  I confirmed on the respective hosts that the MACs are correct:
Vlan    Mac Address       Type        Ports
 All    0011.bbb0.99c0    STATIC      CPU
 All    0100.0ccc.cccc    STATIC      CPU
 All    0100.0ccc.cccd    STATIC      CPU
 All    0100.0cdd.dddd    STATIC      CPU
   1    047d.7ba1.42ab    DYNAMIC     Fa0/7
   1    b827.ebeb.b987    DYNAMIC     Fa0/6
Total Mac Addresses for this criterion: 6
The problem is that I can't even ping the switch from either device.  Linux gives back a "Network is unreachable" error while Win7 "Transmit failed. General Failure".
I've reset the switch to factory defaults by:
  1. Doing a write/erase, deleted the vlan.dat file and reload.  Seeing how that didn't work...
  2. Held the mode button for 10+ seconds
Neither method has fixed the issue.  I am well and truly stumped.
Any ideas?
6 Replies 6
cadet alain
Can you confirm your vlan interface is up/up with following command on the switch:
show ip interface brief | i Vlan
Alain
Have you ruled out any firewall issues on the client machines?
very best wishes
Mike
KenWynWilliams
first off remove the default gateway address as it's wrong not required and won't help. Have you confirmed the workstations have ip addresses on the same network?
try pinging the workstations from the switch and check they are in the arp cache.
regards
ken
Martin Carr
Level 4
Level 4
As said, it's most likely the interface is shutdown (Assuming you have established a console session to the switch).
It's also a good idea to encrypt your passwords to prevent 'shoulder surfing'!
Martin
paquinjrm
Turns out I had to force an IP address on the host (didn't think I had to).
Thanks for the assist everyone.  I'll go bury my head in shame.  :)
Martin Carr
Level 4
Level 4
What you mean is you had to manually assign an address, which you will have to seen as you don't have a DHCP server. The Windows client would have had an 'APIPA'.
Martin
