Can't ping devices in a subnet
SpoonOverlord
   I'm a student, and I have a small project for my exam where I need to make an infrastructure with only four clients. I found a way to make a load balancer between two web servers (subnet 3). But before the load balancer, I noticed that I'm unable to ping a server in the subnet 3 from the subnet 2 or 1. But I can ping between subnet 1 and 2 without any problem. Do you have any idea where I made a mistake? It may be dumb, I really don't know.
I put my .pkt file in attachments. As for now, there is absolutely no passwords on switches and routers. I'll add them later when this problem will be fixed.
there is no routing on either router. Add the static routes below:
R2
ip route 192.168.1.0 255.255.255.248 192.168.2.1
R1
ip route 192.168.3.0 255.255.255.248 192.168.2.3
Attached the revised file.
Mohsin Alam
Easy way to fix this is to go in simulation mode and ping from 1 to 3 and follow the packets by opening and looking at where they getting dropped for what reason and make the necessary changes!
## Make sure to mark post as helpful, If it resolved your issue. ##
R2
R1
Thanks you, your solution fixed the problem
Have a nice day
