10-18-2017 01:04 PM - edited 03-08-2019 12:24 PM
I'm doing a lab about NAT and I came to a point where I need an explanation because I really don't know whether there is an issue or not.
My lab is shown as per the photo. my router conneced to ISP router and connected to switch for Lan Users.
I am using PAT to nat all Lan users to the internet with one single IP. when I did the lap and configure NAT. I can see the translations is working and I can ping from inside Lan (192.168.1.0/24) to the outside address (50.3.3.3) with natted ip of the Wan interface(1.2.2.2). But When I go to server (50.3.3.3) and try to ping the inside Lan (192.168.1.0/24)I can only ping one IP out of the subnet and the rest dropped.
Now I'm wondering is this ok in Pat (NAT overload) to be only able to ping from Inside to outside and not vice versa or something wrong with my lab and it should be pingable. and please if someone explain how the traffic flow is done in NAT to know how to troubleshoot..
Note: I am using Vmware stations as host to confirm the ping reachability.
Thank you
Solved! Go to Solution.
10-18-2017 04:27 PM
10-18-2017 04:27 PM
